PCM swapping between 98 & 99-00 T/A's do you guys know if PCM's are interchangable between the 98 and 99 & newer models? The cars in question are a 98 T/A A4 and a 00 T/A A4. If the PCM's were swapped between these two cars, would they work? :cool: thnks |
Re: PCM swapping between 98 & 99-00 T/A's The pin outs are different so you cant just direct swap. JR |
Re: PCM swapping between 98 & 99-00 T/A's hmm..that sucks you say it's not a "direct" swap. Can it be done somehow? Or is it not worth the trouble? |
Re: PCM swapping between 98 & 99-00 T/A's The 98's have a unique PCM. 99 & up are all the same with different programming. Only way for a direct swap would be the entire wiring harness at the same time :eek2: |
how hard is it to swap the wiring harness? |
It required changing the cluster, and fuel tank to use all OEM parts. A big pain... Ryan |
so can i just leave the 98 pcm and harness alone and then install a 99+ engine ? |
Yes, the 99 engine has all the same sensors in the same locations. So you can use your 98 engine harness with it. Except the 99 has a 2 wire coolant temp sensor, and the 98 has a 3 wire. So keep the 3 wire sensor from the old heads. |
thanks anything else different when swaping between years? josh |
just buy a new harness you can get one for about 550.00 At superior harness company 501 982 1050 with new plug and new wire and heat shrink boot |
Just get a BS3 :) |
| All times are GMT -5. The time now is 06:21 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
