Stand Alone ECM's. Where are you mounting them?
Old 06-02-2008, 12:03 AM
Dwn Cam's Avatar
Default Stand Alone ECM's. Where are you mounting them?
I have a Holley Commander 950 Pro with Injector convertor box and I am wondering where people are mounting their stand alone systems? If you are mounting under the passenger side dash, what are you using to mount the controllers? Any pictures would help to me give me ideas.
Old 06-02-2008, 10:40 AM
Dwn Cam's Avatar
Come on now. All the bad *** cars on this site and no stand alone ECM's?
Old 06-02-2008, 06:14 PM
ssvolvo's Avatar
I would mount it inside the car as I don't think the 950 ECU is weatherproof.
You might post up on www.chevytalk.com in EFI forum. Somebody has done this in a 3rd gen before. Imjust finished a 70 Monte Carlo and I mounted that 950 on the heater box inside the car...works well.
Old 06-02-2008, 07:35 PM
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
Definitely inside the car. The Commander 950 case is not water proof or very heat resistant. Store it like fine wine, in a cool dry place.
Andrew
Old 06-03-2008, 01:18 PM
Dwn Cam's Avatar
I've spoke with Doug Flynn over at Chevy Talk a few times. Very Knowledgeable guy. I am thinking of mounting it under the passanger side dash where the stock one was, now i would lkie to see some pics of others installations.
Old 07-12-2008, 06:38 PM
Dwn Cam's Avatar
I am scratching my head wondering where I am going to mount 3 boxes inside the passenger side dash. Mounting flush against the firewall would be great but then the screws would protrude through the firewall into the engine bay and that looks like ***.
Old 07-12-2008, 06:50 PM
Jake@EPP's Avatar
Under the HVAC controls theres a good amount of room. I have mounted a bigstuff there before to maintain a clean install.
Most race-car apps typically get it installed to the firewall (HVAC delete panel) on the inside.
Old 07-12-2008, 09:47 PM
Dwn Cam's Avatar
I have completly deleted all air ducting and heater core system from the car. There is a very large empty space where the stock ECM resides. The only flush panel past the dash is the firewall.
