LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   Do I need differn't Injectors? (https://ls1tech.com/forums/pcm-diagnostics-tuning/93140-do-i-need-differnt-injectors.html)
6spdTA Aug 12, 2003 02:30 PM
I just got my 5177 kit installed and had a buddy work the MT2500.
We got a freeze frame of a run with a 75 shot.
Injector pulse width max was 21.8.
and O2's were reading .930.
This is with a custom tune with a preditor.
Is there anything else I should check or change?
Thanks for the help.
NoGo Aug 12, 2003 05:48 PM
Re: Do I need differn't Injectors?
Yes, you need to increase the size of your injectors. 99-00 cars came with BABY injectors.
Nitrous requires a little more fuel than N/A. Additionally, it is very easy to get a different amount of nitrous into the car (bottle pressure / intake pressure, solenoid flow etc...) over different runs. Due to this reason, it would be in your best interest to have a "fuel cushion" and install some larger injectors.
A lean condition N/A just means a little bit of knock. A lean condition under nitrous means you collaps a ringland (read: new motor). Larger injectors would be good insurance.
© 2026 MH Sub I, LLC dba Internet Brands
