Predator shifting??
Old Sep 2, 2003 | 07:46 AM
ChazLS12002's Avatar
Default Predator shifting??
I have a Predator with the line pressure at +25% and -25% for the shift timing, but I don't get good crisp shifts instead it slams and jerks hard like three times then finally shifts!!! WTF
Old Sep 2, 2003 | 12:06 PM
Kansas 99z28's Avatar
Default Re: Predator shifting??
you probably have too much time out. I have my shift time at -10% in every gear and it shifts quick. You also have to be careful on how much pressure you put it on cuz you will damage your pump.
Old Sep 2, 2003 | 01:14 PM
Ok, I'll try putting the timing at -10% any ideas on the pressure? Thanks!
Old Sep 2, 2003 | 01:16 PM
CAT3's Avatar
Restricted User
Well i have had mine at +25press/-25 time since i have had the Predator and no problems. Shifts quick and hard at WOT, maintains the normal shift at cruise/PT.
Old Sep 2, 2003 | 01:26 PM
Could the year of the car have anything to do with it(2002 Z28)? Maybe, Torque Management?
Old Sep 2, 2003 | 03:47 PM
predator gets rid of torque management
Old Sep 2, 2003 | 09:53 PM
Well in a few other post I have read here it says otherwise, I don't mean to sound rude or smartass, but the guys who have said this seem to know alot!!! Can anyone else verify this??
Old Sep 3, 2003 | 01:36 AM
CAT3's Avatar
Restricted User
Kansas, not to ba an *******, but havent I already covered this with you? TM is not fully deleted, hell sometimes barely adjusted, and yes it more prevelant in the 02 models. might have something to do with your problem.
Make sure you have a cooler also, sometimes, my trans wil buck and shift really hard but not in a good way if i run it til it downshifts goign up hills and the likes, not often, but it does. Pull over, shut car off for 15sec, restart and its back to normal. Maybe the Yank convertor, maybe hot, dunno.
Old Sep 3, 2003 | 07:00 AM
Its like a bucking!So should I get a Transcooler, even though I don't have a TC?
