Help need to know how to lean out car!! Don't have LS1 edit Well like the title says, I can't figure out how to lean out my car without LS1 edit. I have a MAF translator, but it only made the car run more rich even with it turned full lean. So I took it off. I have a SLP 85mm MAF. I am running about an 11.5 AF ratio. I have to check the dyno sheets at home to see for sure. Any help would be greatly appreciated. Also if anyone knows of a shop with LS1 edit near L.A. please let me know. 99 T/A WS-6, A4, Direct flo airlid, 85mm MAF, LS6 intake manifold, no EGR, QTP LT's, ORY pipe, Dual QTEC's, Corsa cat-back, HPP3 for shift points and firmness, MSD 8.5mm wires, NGK TR55's, Corvette ZO6 wheels 18x9.5, BFG's 265/35's. :drive: 331 rwhp/ 338 rwtq cutouts closed 332 rwhp/ 343 rwtq cutouts opened |
Re: Help need to know how to lean out car!! Don't have LS1 edit You can use the AMFT to lean the car out it works... maybe you went the wrong way with the switches. |
Re: Help need to know how to lean out car!! Don't have LS1 edit If it's already lean (+LTFT) then leaning out further will only jack up the cruise LTFT and lock it in at WOT, dumping more fuel, not less. If you found a buddy with a Predator you could at least do a little monitoring to see if this is what's up (can't touch, but can look with someone else's Predator). |
Re: Help need to know how to lean out car!! Don't have LS1 edit Put the stock MAF back on and try again. |
Re: Help need to know how to lean out car!! Don't have LS1 edit any other suggestions?? How much horsepower can the stock maf carry?? |
Re: Help need to know how to lean out car!! Don't have LS1 edit prolly the same as the SLP 85mm MAF :) (isn't the opening to the intake manifold only 80mm?) |
Re: Help need to know how to lean out car!! Don't have LS1 edit I don't know the opening to the intake manifold. Is it the same for the LS1 and LS6 intake manifold??? |
Re: Help need to know how to lean out car!! Don't have LS1 edit the opening on the ls1 and ls6 manifold and throttle body are 75mm. according to my ls1 ls6 performance book. |
Re: Help need to know how to lean out car!! Don't have LS1 edit anyone else have any suggestions?? OR perhaps where can I get LS1 edit. Thanks. |
Re: Help need to know how to lean out car!! Don't have LS1 edit you can get ls1 from carputing.com, it costs $550. i would go half and half on a 2 vin cable it costs $750, but i think you only get one cable :( |
| All times are GMT -5. The time now is 09:40 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
