Factory Top speed?
Factory Top speed?
I was wondering what is the factory top speed of a base ls1 trans am equipped with an A4 and 3.23 gear ratio? How about 2.73 equipped cars? Thank you.
well I almost buried my speedo buried with a hypertech tune and a air intake, 155ish maybe a little under, (Tough to c what you are doing going that fast) wasn't totally buried with my stock gears. Now more buried HEHE.
The factory speed limiter was set according to the factory tire speed rating. If you didn't have Z-rated tires, the limiter was set lower than 162 (I can't remember the combinations for A4s).
Location: The dirty taint of the country. ...Los Angeles
I've taken her to the max when she was stock. Not sure what the speed was but I held it for a few minutes. Yea, uuuummmm, when the A-Pilars vibrate like that when your topping out you can't help but wonder how bad it would suck if you flipped at those speeds. lol
I read and heard 162 factory, did that with my stock 2.73 fior about 20-30 seconds after looking down and seeing I was past the 155 mark. Changed to 3.42s and haven't been in the right place\time to see what I get to. Added lid\headers\stall\gears\tune since the 160+ ride.
I will 1 day when the time\place is right see if I can get there again.
when I still had the 3.23 stockers mine hit about 160, then backed out due to the road starting to get iffy. I'm sure even with 3.73 gears it'll still go that fast now.
