Need help finding this part for power/gnd module
Old 09-04-2010, 09:05 AM
mrrman's Avatar
Default Need help finding this part for power/gnd module
I am rebuilding my car and have installed HID lights, new dual amps, crane ignition system and will be upgrading my fog lamps later. I have all these power and gnd cables but no room to mount them on my battery. Is there some kind of strip that I can bolt to the firewall and attach all these leads to it then run one cable to the battery for each power and gnd? I dont know the name of this or where to get one. Thanks for your help.
Old 09-04-2010, 07:53 PM
eseibel67's Avatar
Grounds are everywhere of course. But get your power from the underhood fuse block, there are empty slots you can use.
If you need even more, you can buy an auxillary fuse block. Under "PART NUMBER", type FH27 and take a look:
http://eaccess.smpcorp.com/eCatalogs...logSearch.aspx
Old 09-06-2010, 09:04 AM
mrrman's Avatar
I wanted to go another route since some of these termnations are quite big. I didnt want to use the fuse blk thats there.
