will used instrument cluster read correct mileage???
Old 12-09-2011, 03:20 AM
2000SSMAN's Avatar
Default will used instrument cluster read correct mileage???
Hi,
One of my guages might be messed up in my instrument cluster and might have to get another cluster so i was wondering if i swapped them out if my car will my car still show the correct mileage and if not please explain if possible. All help is appreciated.
Old 12-09-2011, 07:24 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Negative. The accumulated recorded mileage is stored in the cluster electronics.
Sorry!
Old 12-09-2011, 08:18 AM
mrrman's Avatar
in my 87 TA, I moved over the mileage chip to the "new" digital panel and it worked...mine has the digital console however
Old 12-09-2011, 12:16 PM
2000SSMAN's Avatar
Is there any way to reprogram one...does a dealer have any access to anything like that...can the Guage be fixed?
Old 12-09-2011, 05:46 PM
Paul Bell's Avatar
I don't think it's legal to do so unless a dealer was replacing a cluster. They'd have to have the car in their possession for service. I doubt you'll find anybody to take your odometer and change the numbers.
Old 12-10-2011, 01:16 AM
2000SSMAN's Avatar
So if I got another cluster a dealership could fix it or would it have to be a brand new cluster that I have to buy through them? Btw. That blue ta looks really good
Old 12-10-2011, 01:31 AM
vrtch ss's Avatar
The dealer will sell you one and require your old cluster in exchange as they rebuild them and resell them. Also they will program it to your current mileage.
Old 12-10-2011, 06:28 AM
Paul Bell's Avatar
This is the company GM uses to service gauge stuff:
http://www.modelelectronics.com/index.asp
Old 12-30-2011, 04:37 AM
7998's Avatar
Question. Will the car be branded as TMU or odometer descrepacy on Carfax or the title?
Old 12-30-2011, 06:32 AM
Paul Bell's Avatar
What is "TMU"?
Old 01-01-2012, 05:39 PM
7998's Avatar
Originally Posted by Paul Bell
What is "TMU"?
TMU=True Mileage Unknown. A lot of states brand the title as such if there is a odometer issue which affects the value. Kind of like Flood, Salvage, etc..
Old 01-02-2012, 03:05 AM
_JB_'s Avatar
Originally Posted by 7998
TMU=True Mileage Unknown. A lot of states brand the title as such if there is a odemteter issue which affects the value. Kind of like Flood, Salvage, etc..
FL does a mileage exempt if the car is 10+ years old.
Old 01-02-2012, 10:23 AM
7998's Avatar
PA does that too, not sure if it's 10 or 20 years old. Mileage exempt and TMU are two different things. Mileage exempt can be from age, TMU means there was a problem with the miles reported.
Old 01-02-2012, 01:01 PM
idformula's Avatar
This is the only place that I know of
http://www.tacomaspeedometer.com/index/
Old 01-02-2012, 02:45 PM
_JB_'s Avatar
Ah ok thanks for clearing that up. :-)
Old 01-05-2012, 01:34 AM
DrJele's Avatar
hi
i was having a similar problem and searching the web i found this site : www.correct-mileage.co.uk/.
they solved my problem.
hope it helps.
Old 01-05-2012, 07:21 AM
Paul Bell's Avatar
Welcome to LS1tech!
Here in The US, there are federal laws that pretty much prohibit odometer rollback.
http://www.rolledbackodometer.com/fe...meter-law.html
Old 01-06-2012, 12:28 PM
the impaler's Avatar
Paul, your link seems to only cover odometer fraud, I'm not sure it would apply in this case, if the op is trying to set the correct milage.
Old 01-06-2012, 08:53 PM
Spartan7's Avatar
Some companies can roll the odometer forward for you, that's legal. Rolling it back is definitely illegal. You'd have to buy a new one from the dealer and have them set the correct mileage.
Quick Reply: will used instrument cluster read correct mileage???
