My rebuild of a 1998 trans am
#41
It's a slow process but in the end will be worth it. If you weren't seeing much rust or having engine trouble I would wait until it needs to be done then go with it from there.
ok so rad support is on and dynamat is in as well. Im getting ready for the engine to be put back in and am still a little behind on what i need for the hvac delete, i have the panel what else needs to be done?
also does anyone know if egr is required for a state inspections
#42
It's been about five years or so but I use to over see several inspection stations as part of my job. From what I recall, if the underhood stickers show that it had an EGR from the factory (or if the stickers are gone, the spec books the inspection stations are required to have will show it as having had one when new) then it is supposed to have one. The good news however is that the inspection process does not include the proper function test(s) of said smog parts. They just have to "be there" and appear as if the are "correctly installed and connected."
Where in Maryland are you? I'm out west where we don't have to go through smog testing.
Nice progress on your Bird!!!
#43
Every state can be different when it comes to smog laws. For example, 1829 is dead wrong for AZ laws. We don't have an underhood inspection for OBDII vehicles. They simply plug in to the ALDL connector and test the fuel cap and fuel tank for vapor leaks. If the component isn't working, it will flag the inspection and you will fail. Now, if there is no code, there is no problem and you pass since they don't pop the hood. Do you understand what is being said here??
#44
Anyone on hvac delete?
Engine bay is all done
decided im doing ctsv brake conversion and a few other things hopefully motor is back next week
#46
ran some wires interior shouldbe in by the weekend and motor should be done any day now.
is this where is should cut out for the trap door mod? ill be using a plastic tank.
also looking into getting a new rear end what should i get engine mods will be
wesico pistons
k1 rods
ms3 cam
ls6 intake
1 7/8 headers
true duals
texas speed tune or some other tune
also what injectors and tune should i go with?
wesico pistons
k1 rods
ms3 cam
ls6 intake
1 7/8 headers
true duals
#50
http://i178.photobucket.com/albums/w...7/60d03760.jpg
#52
http://i178.photobucket.com/albums/w...7/f9ad4032.jpg
More progress, new rad support is going on tonight hopefully by the weekend interior is painted and so is the underneath so it can start going back together!
#53
Car has been neglected lately, ordered the rest of the parts for the engine and just need a few more and then she should be all back together
short block is being assembled now, ordering k member friday and engine should be in within the next few weeks
starting to look good again
used some eastwood chassis black on the bottom
trap doop mod done
#57
i thought you had to run one though, or atleast thats what i was seeing sme places i guess not.
also to anyone with ls2 lifter trays on a ls1 does the divit go up or down when installing them?
