My rebuild of a 1998 trans am
she has 236k on her right now as she sits, its a 1998 6 speed trans am. I plan to do a motor swap next year. Just wanna get her back up together and running first.
when i picked it up
beside my dads project
After day 1
plans as of now
repaint jetstream blue
new clutch
havent decied if im going to build the motor or do a ls2/ls3 swap yet
newrims and tires
ws6 ram air hood if i can find one
problems i have had that maybe you can help with
the security light keeps coming on, one the dash and wont let me start the car with either key. I know there is a bypass, but is there any other way to fix it?
Any comments or uggestions are appriciated.
btw dont mind the messy garage theres too much stuff and cars in there right now it needs to be cleaned up.
when i picked it up
After day 1
plans as of now
new clutch
newrims and tires
nice to see you saving one instead of parting it... How much did you give for it? pull out the ignition switch and check the two white wires, they usually fray and rub causing it to have a vats fault... you can also check under the column and make sure theyre not cut... welcome, you can find all the info youre gonna need here...
Security light issue is easily bypassed with a simple resistor. But if you want to fix it you'll need to open up the steering column. You sure you don't want to just bypass?
i might just do the bypass its really anoying to not be able tomove it over in its spot in the garage.
Ive been searching around here for like a week and there is tons of good info knew that before i got the car though.
I paid $2600 for it and ive wanted one for a long time ever since my dad go his 25th anniversary trans am, just like the newer ones better.
I need to just steal his ls1 out of his vette though and put in this only has 27k on it lol, yes we have too many cars lol.
yeah probably just gonna get it back together for spring with paint and everything and see if this ls1 lasts until next winter for a swap then.
Couple more questions i have
Do you have to drop the engine out through the botom like i keep seeing, or can you pull it through the top?
Do the xlr(c5) brakes have brackets so i could use them on the trans? i have a set laying around.
either way is fine.. if you have never done it from the bottom the just pull from the top, it will be easier than learning to do it from the bottom... if you know what youre doing, you can drop it pretty easy..
I have no idea bout your other question.
yeah i searched a little more about it and found out the top was fine too, i know the bottom is easier but i dont have a lift yet. Plus the front end will be off so i could do the bottom and just slide it out also.
yeah i have a long one needed it to get the engine out of my camaro, its actually still holding that motor up come to think of it lol i might wanna work on that tomorrow.
Planning to get all of the other body stuff off tomorrow and preped for paint by the end f the weekend. Cant wait for this thing to be done!
new updates
Still cant get it started after the bypass, got a code p1626 the security code, so i deleted it in hpt and going to try that out tonight, from what i understand that will fix it.
These are the things on the side skirt i cant figure out, tried to pry them out but dont want to brake the skirt. Should i just drill them out?
And the fender mounts got messed up on both sides, gonna need a little body work, all the minch welds look like they had a jack under them forever. Oh well nothing a little hammering cant fix lol
new updates
ok thanks just wanted to make sure, i was just confused because one side had bolrs and the other side had these
Cut the exhaust out and finally got it running tonight. Only panel that should need replacing anyone know the name of it?
1 Post
I like threads like this good luck and keep us posted
how easy was it to remove the engine i want to remove everything when i paint my car
some more progress made
http://i178.photobucket.com/albums/w...7/723940f8.jpg
honestly not that bad, could be done in a weekend i just didnt have much time to work on it did it parts at a time. Have a good video if you would like to see it that i used as a guide.
Update: Block was dropped off and most interior pieces ordered.
Also thinking about doing an antenna delete i dont know yet though thoughts?
Took the engine in should be ready for paint after the weekend, pictures to come later today
