Dropping the fuel tank, 96 LT1 Trans Am
Before I drop the fuel tank to replace the pump, I wanted to ask--How much space is there between the interior steel trunk panel and the surface of the fuel tank? I was going to use a reinforced Dremel cutting disk to make the fuel tank access panel.
Any recommendations? I have true duals that clear the tank, so dropping it shouldn't be too hard if I have to. Thanks.
