2002 Trans Am Build Codes Break-Down
Greetings All,
Can anyone point me to a site that breaks-down the build codes on a 2002 Trans Am?
I would like to decode the build sticker on the door.
Thanks
Mike
Thanks
Mike
This may not be all of them, but it is a lot of them.
AG1 Power Adjuster, Driver Front Seat, Multi-Directional
AK5 Inflatable Restraint System, Driver and Passenger Seat
AQ9 Front Bucket Seat, Driver and Passenger Recline
AR9 Front Bucket Seat, Driver and Passenger Recline, European Style
AU0 Remote Entry Lock Control
AU3 Side Door Electric Lock Control
AX4 Restraint Conversion Seat, Manual European
A26 Window Glazing, European
A31 Window, Power Operated, All Doors
A90 Lock Control, Right Component Lid, Remote Control Electronic Release
BAG Parts Package Export
BBS **** Shifter Hurst
B35 Covering Rear Floor Mats
B9W Wiring Provisions, DRL Override
CC1 Roof Hatch Removable Panels, Glass
C49 Rear Window Defogger, Electric
C60 HVAC System AC Manual Controls, Front
DD9 Mirror, Breakaway, O/S LH & RH Remote Control Electric Color
DE4 Sunshade, Removable Hatch Roof
DG7 Mirror, O/S LH & RH Remote Control Electric Color
DL5 Decal, Roadside Service Information
DS1 Sales, Diplomatic
D21 Sunshade, Windshield
D35 Mirror, O/S LH Remote Control, RH Manual Control, Color
ETA Harness, I/P Wiring #1
FE2 Suspension System, Ride and Handling
FE4 Suspension System, Special Ride and Handling
FE9 Certification, Federal Emission
FLT Fleet Processing Option
F41 Suspension System, Front and Rear Firm Ride and Handling
GU2 Axle Ratio 2.73, Rear
GU4 Axle Ratio 3.08, Rear
GU5 Axle Ratio 3.23, Rear
GU6 Axle Ratio 3.42, Rear
G80 Axle Positraction, Limited Slip
JAF Brake Provisions, European
J65 Brake System, Power, Front and Rear Disc
K05 Heater, Engine Block
K29 Module Powertrain Control
K34 Cruise Control, Automatic, Electronic
K43 Generator, 102 Amp
K68 Generator, 105 Amp
LS1 Engine, Gas V8 5.7L SFI Aluminum
L36 Engine, Gas V6 3.8L MFI HO
MAE Marketing Area Europe
MM5 Merchandised Transmission, Manual 5 Speed
MM6 Transmission, Manual 6 Speed O/D
MN6 Merchandised Transmission, Manual 6 Speed
MX0 Merchandised Transmission, Automatic O/D
M30 Transmission, Auto 4 Speed Electronic
M49 Transmission, Manual 5 Speed O/D
NA3 Emission System, Japan
NC1 Emission System, California
NF7 Emission System, Federal
NK3 Steering Wheel, Sport, Soft Rim, Simulated Leather
NM2 Emission System Export, Leaded Fuel
NP5 Steering Wheel, Leather Wrapped
NP7 Steering Column, EEC Approved
NT3 Emission System, EEC 00
NW9 Traction Control, Electronic
N36 Steering Wheel, 4 Spoke Sport
N60 Wheel, Aluminum, Painted
N66 Wheel, Styled Aluminum
N73 Wheel, Custom Sport Var4 17"
N92 Cover, Wheel, Bolt-on
N96 Wheel, 16 X 8 Cast Aluminum
N98 Wheel, 16 X 8 Cast Aluminum Chrome
PA6 Wheel, Styled Painted
PW7 Wheel, 16 X 8 Aluminum Styled
P05 Wheel, Chrome
QB3 Wheel, 16 X 7.5 Steel
QCB Tire, All P235/55R16-96T BW
QEA Tire, All P215/60R16-94T BW
QFK Tire, All P275/40R17-93W BW
QFZ Tire, All P245/50R16 BW
QF6 Wheel 17 X 9, Aluminum
QII Tire, All P215/60R16-94H BW
QLC Tire, All P245/50R16/N BL
TR7 Headlamps, Control Leveling System, Automatic
T2H Ornamentation Exterior, Export Unique Requirements
T2J Ornamentation Interior, Export Unique Requirements
T37 Lamp, Fog, Deluxe
T39 Lamp, Turn Signal, Auxiliary
T43 Spoiler, Rear
T65 Lamp System, Daytime Running, Export
T72 Headlamps, LH, Rule of the Road
T78 Headlamp Control, Delete
T79 Lamp, Fog Rear
T82 Headlamp Control, Automatic ON-OFF
T84 Headlamps, RH Rule of the Road
T85 Headlamps, LH Rule of the Road
T89 Lamp, Tail & Stop, Export
T90 Lamp, Signaling and Marker, Export
T96 Lamp, Fog
UA6 Theft Deterrent System
UB3 Cluster, Instrument, Oil Cool Temp Volts Trip Odom Tach
UC2 Speedometer, Instrument, Kilo & Miles, Positive Bias
UD4 Alarm, Vehicle Speed, 120 K/H
UK1 Frequencies, Japanese
UK2 Lever, Directional Signal, Includes Multi-Functions
UK3 Control, Steering Wheel, Accessory
UL0 Radio, AM/FM Stereo Seek/Scan Auto Rev Music Search Cass Auto-Tone Clock ETR
UL2 Frequencies, European
UL8 Frequencies, Saudi Arabian
UM6 Radio, AM/FM Stereo Seek/Scan Auto Rev Cass Clock ETR
UN0 Radio, AM/FM Stereo Seek/Scan Compact Disc Auto Tone Clock ETR
UQ0 Speaker System, 4 Dual Front Door Mounted, Dual STD RGE, Qtr/Shelf
UW3 Radio, AM/FM Stereo Seek/Scan, Auto Rev Music Search Cass Data System Clock ETR
UZ7 Speaker System 8, Quad Front Door Mounted, Dual Sail Panel, Dual Rear Hatch Amplifier
U12 Speedometer, Dual Scale with Kilometer Odometer
U19 Speedometer, Instrument, Kilo & Miles, Kilo Odometer
U59 Speaker System 8, Dual Front Door Mounted, Quad Sail Panel, Amplifier
U73 Antenna, Fixed Radio
U75 Antenna, Power Radio
VA5 Language Label, English
VD1 Provision Options, Europe
VE1 Provision Options, Japan
VE2 Protector Source Applied
VG1 Protector, Underhood Compound, Clear
VG4 Protector, Undervehicle Compound, Black
VG9 Protector Wax, Exterior Body
VH5 Plate Vehicle Identification
VI6 Fleet Incentive, American Standard
VJ1 License Plate Rear Mounting Package, Japanese
VK3 License Plate, Front Mounting Package
VL4 License Plate, Front Mounting Package, EEC
VL5 License Plate, Rear Mounting Package, Export
VL6 License Plate, Front Mounting Package, Japanese
VP6 Noise Control
VR6 Hook, Tie-Down, Shipping
VR7 Hook, Tow, Second, Rear
V12 Cooling System, Power Steering Fluid
V76 Hook, Tow
WS6 Performance Package Special
WX7 Wiring Provisions
W53 Entertainment System Option C
W54 Entertainment System Option D
W55 Entertainment System Option E
W66 Merchandised Package, Formula
W68 Sales Package, Firebird Ground Effects
X10 Entertainment System, Option L
X20 Entertainment System, Option M
Y3F Sales Package, Sport, Appearance Upfitter
Y4A Exhaust Cat Back
Y4B Provisions Level II Ultra Performance Suspension
Y4C Lubricant Engine Oil & Performance
Y4D Axle Torque Sensing Differential
Y4E Cooling System Engine Oil
Y4F Provisions Hurst Shifter
Y4G Provisions Chrome Wheels
Y4H Ornamentation Dash Plaque & Key Fobs
Y4J Covering Floor Front Mats
Y4K Protector Car Cover
Y4L Provisions Spoiler
Y81 Merchandised Package, Firebird
Y82 Merchandised Package, Firebird, Trans Am
Y84 Merchandised Package, Firebird Trans Am, GTA
Y87 Merchandised Package, Performance Enhancement
1R3 Vehicle Identification Label 1
1R4 Vehicle Identification Label 2
P05 Wheel, Chrome
T43 Spoiler, Rear
T79 Lamp, Fog Rear
T96 Lamp, Fog
VP6 Noise Control
V76 Hook, Tow
If that doesn't this link (courtesy unit) from the How To thread should do it.
http://www.wiu.edu/users/muwtj1/rpocodes.htm
