Interior courtesy lights don't work.......
Car is a 2002 WS6 T/A with t-tops. The interior lights located on the rear view mirror do not work. Everything else works inside. Is it difficult to change the bulbs? What else should I check? I am under the impression that the interior lights share a relay with the lock or dash lights but those work fine so it probably wouldn't be a fuse?
Hmmm... I would think the bulbs or the switches on the mirror itself. There is the harness connection at the back the mirror too... Could be loose. But if all other items in the interior work... Probably a problem with the mirror.
If you have power coming to the mirror at the harness with the door open.... Then something in the mirror is bad.
