Look what I found is it real?
can anyone verify this? is this a real MRM Firehawk? there were only a few made,
http://www.autotrader.com/cars-for-s...stingId=0&mmt=[PONT[FBIRD[]][]]&listingId=361835924&Log=0
the hood doesn't look right to me and the color on it is off, looks like a cheap knockoff hood, the "intake bumps" stay the same width all the way to the back of the hood but on OEM hoods it gets wider and spreads out. the hood on the car looks more like a knock-off raptor hood that has the intake bumps of a WS-6.
Where did you come up with that info?!?
http://www.firehawk.org/images/2002-...on-numbers.jpg
That's what CompNine's database was showing, 4 MRM Firehawk coupes w/ M6 built in 2002. DISCLAIMER: As noted in that breakdown, another data source was showing a larger total # of Firebirds (including Firehawks) having been built in 2002 than what CompNine was reporting, so it is quite possible that there were more than 4 MRM Hawks or other model Firebirds built that were not accounted for in that breakdown.
A couple things I would be worried about, the hood, which like someone said earlier is a SLP HO hood. And if you look at the back panel which usually says "firebird" Formula" Trams Am" Or Firehawk" it's blacked out. A car with 7000, that should have held up. I know in the add he said it's a very custom car, so I wouldn't expect it to be a firehawk.
