Drivers side window issue
Hey all,
I am pretty sure I know the answer but before I go and spend a fortune on new parts and rip my door panel off, I am having issues with my auto drivers side window.
Symptom - when selecting up or down, it only goes a few inches and stops. After giving it a minute, I select it again and it will go another few inches. Almost like it has to recharge a little. I am pretty sure the motor may be toast but it is a fairly new motor that was replaced by the old owner for the same issue. So I am thinking there is possibly something else which may cause this.
Reason it is a huge issue, it it a 2002 WS6 convertible and the windows are used often. Really looking for any other suggestions before I get my hands dirty.
Thanks in advance.
Thanks in advance.
Unless you rewire the passenger window with the autotrix fix both motors have a tendency to burn up fast especially if your using them at the same time. I was replacing at least one motor a year until i redid the wiring on the passenger side. I got my motors from autozone and they have a lifetime warranty so I would just go switch it out whenever it happened on both sides. Haven't had to do that in a while now and plus both windows go up and down quicker now.
Save the manuals!
Letting the motor rest for a few minutes, will allow the resistor to cool off a bit to the point where you can move the window a little bit more. Pushing or pulling on the glass may give it enough "help" so the glass will move further in between times where the resistor craps out on you.
You'll want to address this ASAP, because the problem gets (quickly) progressively worse.
Dorman has created an all-new motor with an updated design that performs MUCH better than the OEM unit. So, you'll want to get the new updated design for your replacements. Don't be tempted to get the "original" part - it's been out of production for a long time and odds are that you'll purchase a reman - even if its marketed as "new." This site is full of posts where our members have installed "new" OEM motors to have them go belly-up right out of the box.
You'll also want to be sure to read up on the "shbox method" for changing the motors. It will make the job MUCH easier and will do less damage to the door. Changing the motor with GM's factory procedure puts a lot of stress on the regulator rivet holes and can do huge $$$ damage to the door.
The ONLY thing Autotrix kits do is reduce the normal voltage drop that the motors see. This makes a bad motor look better than it really is.
There is nothing wrong with the circuitry in the cars. If there was, there would have been problems with cars coming from the factory. (that didn't happen)
IMO - Now that the new motor design is widely available, with a lifetime warranty, relay kits are a waste of money.
Thanks for the advise . I will be looking at a new motor. If I am gonna do it, especially to this car, I want to make sure it is done right. That also explains why the old owner replaced it not long ago and the issue is back. Thanks all for the info. I will be looking around for a new motor. Cheers and thanks.
