1996 Firebird Headlight quit opening problem
Gentlemen the headlight door on the passenger side will not open. I have replaced the motor twice in the last several months. It worked intermittently but now not at all. I decided before returning this to the auto parts store again I would do some checking on my own. I checked the power to the motor at the plug-end and found it was dim and the other side headlight is bright and this is with the car off. I'm not sure why the plug is hot when the car is off? I'm thinking it must be a hot ground system. I have checked the harness underneath the ground straps and cleaned both the harness and ground straps. I still have low voltage at the plug. I went to the fuse box and checked it and it was good power to the fuse box. I ran new wires from the fuse box to the plug and got a bright light on my tester. Then I plugged it in and turned the switch on and the fuse blew. I am really stumped. Any answers, ideas, I could use help. Thanks, The Duckster
