rear dome light blowing fuses?
So I went to replace rear dome light in the ta, and instantly blows the fuse, switch out the fuse and blows that one right away too. Why would it do this?
And on another note, there's this tick noise like every 15 seconds coming from the glove box area, Wtf is that? Almost sounds like a turn signal click
Did you do something to **** off he mafia? Lmao
In all seriousness, it could be the body control module as that is what controls all your interior lights. It could also be a short in the wiring. If I were you I would unplug the light until I found a replacement bcm and tried it. Just one thing if you replace the bcm you will not be able to start the car if it is a used module. However you will be able to narrow down the problem. (In order to start the car you would have to put the old module back in)
