my 2000 trans am ram air project
Old 12-13-2014, 03:50 PM
jaygt's Avatar
Default my 2000 trans am ram air project
I just got this 2000 trans am six speed. I have only had 2nd and third gen trans ams before. around 8 total.
the first day I had it I took it to the car wash. touchless with under spray.
well now it idles fine. starts fine. drives kinda ok. but as soon as I floor it it doesn't run well at all. kinda hesitates and misses.
how do I test things. im thinking of replacing
wires
plugs
front o2 sensors
clean maf
coil pacs?
I replaced the fuel filter didn't help
it has 114 kilometers not miles
sucks I just got it and already I screwed it up
what is most common issue when you get engine wet?
what are most common electrical parts that go bad?
Old 12-16-2014, 08:20 PM
fbody4everyone's Avatar
Yea, definitely check wires for tears, pull spark plugs out and check for damage/carbon build etc..
Maybe check your alternator by using a multimeter on the battery.
At least if its a spark issue, you can limp home unlike a bad alt.....and end up paying to be towed home.
2 weeks ago... found out my alternator was bad in my ws6 and had same issues as you
Btw, nice TA!
Old 12-17-2014, 12:01 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Welcome to LS1tech!
I doubt that you screwed it up.
The ignition coils rarely go bad. Do a proper tune up, wires, plugs, fluids, filters, check the MAF screen for junk, the throttle body for dirt.
MSD wires are good, stay away from Taylor wires. ACDelco plugs #12.
NO FRAM OIL FILTERS.
Old 12-17-2014, 12:19 PM
blaine123's Avatar
Never ever ever take a nice car to an auto car wash. The sprays are high pressure and can ruin light assemblys and spray in areas you don't want water to enter and they seem to always find a way to get water in your rear tail light assemblies... Auto Car washes are for SUV's, Mini Vans, and Trucks... vehicles you don't give a crap about.
Congrats on the new TA. Great Color.
No Codes? An 02 issue or a bad miss will usually trigger a Code. Of course when I forgot to plug in a spark plug wire I didn't get a code running on 7 cylinders for a bit.
IF no code then its hand checking everything and replacing culprits which would cause the type for problem from cheap to expensive. I'd hook up an OBII reader and see what cylinder or cylinders are missing. You can get them dirt cheap on Ebay.
Old 12-17-2014, 12:56 PM
jaygt's Avatar
Thanks so much for the help
I replaced the plugs. Had bosh with 4 prongs. Put ngk tr55 in
Put ngk O2 sensor drivers front
Fuel filter
Still the same
Next up
Clean mass
Bought 8 ac Delco coil packs
New in the box for $115 shipped. Hope not fake somehow.
Msd wires
Slp lid
I'm worried it might be fuel pump ....
Car did sit a lot over last 8 years
One original cat still on it
A guy might of played with computer
Ok what obd11 thing should I get? I'm new to this
Just when I floor it nothing really happens. Like a car with 140 hp
But idles perfect. No smoke no noise not burning oil low mileage
I'm in toronto ontario
Old 12-17-2014, 03:56 PM
blaine123's Avatar
Fuel filter
Still the same
Next up
Clean mass
Msd wires
Slp lid
OBII reader is your preference. Super cheap ones are on Ebay. Just ensure the one you choose can read and clear codes. Also any handheld tuner can do the same if your planning to get one.
Quick Reply: my 2000 trans am ram air project
