01-02 Stock catback
01-02 Stock catback
Does anyone have a 01-02 WS6 stock uncut catback or I-pipe cut carefully catback. I think the 01-02 had the single chrome tip tail pipe on each side. I know this isn't quite right section but if anyone has one they would probably be in here.
That's MISTER MODERATOR
Sounds like you're restoring a car?
I think to get the exact original tails & muffler, you'll need to make a friend at a GM parts counter. The muffler with tails & I pipe is part number 10436321. Looks to be still available-hold on to your hat-it's over 900 bucks.
"LS1 - ENGINE GAS, 8 CYL, 5.7L, SFI, ALUMINUM ENGINE; M30 - TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC; M49 - TRANSMISSION MAN 5 SPD, BORG WARNER, 77MM, 3.75 1ST, .76 5TH, O/D; MM6 - TRANSMISSION MAN 6 SPD, BORG WARNER, 85MM, 1ST 2.66, 6TH 0.50, O/D; NM2 - EMISSION SYSTEM EXPORT, LEADED FUEL; VP6 - NOISE LEVEL CONTROL; WS6 - PERFORMANCE PACKAGE,SPECIAL(MERCHANDISING OPTION); WU8 - SALES PACKAGE CAMARO SS APPEARANCE AND PERFORMANCE;
(LS1/5.7G)"
(LS1/5.7G)"
LS1Tech Administrator
Received 1,489 Likes
There is no difference at all in the catback or muffler/tailpipes/tips between '99-'02 WS6 models. The '98 WS6s did mostly come with a single outlet on the driver's side, though I believe some of the later '98s started receiving the updated dual tail pipe catback even before '99 MY production began.
So you can widen your search to '99-'02, because they are all the same in that range.
Probably best to post this in the "Parts Wanted" section as well.
WS6's and SS' are specifically listed in gm's literature "sales brochure" as having a specific low restriction exhaust any idea if this is fact when compared non ram air or ss car. More so my curiosity now.
Kinda my car has a Borla adjustable on it and depending on how rowdy the exhaust is once complete I may put a stock catback on it to shut her up. If I do go stock catback route I really want the correct one on the car since I'm a nitpick about stuff like that. In the past I've had really good luck with a stock catback and a cammed 6.0,6.2 with LT's and ORY that makes a really nice sounding easy on the ears and tolerable to drive combo. Cars still in paint jail so thinking out loud for now.
So the "low restriction exhaust" is likely referring to the smaller muffler and 0.50" larger tail pipes. The real world difference is marginal and doesn't seem to result in any measurable performance improvement for the WS6/SS cars since they don't dyno higher nor run faster ETs on average. But for a highly modified engine, there might be some actual gain in using the marginally higher flow muffler/tailpipes.
The single outlet '98 SS/WS6 muffler is said to be the best flowing catback that GM ever used for these cars, outside of the SLP dual/dual setup available via a Y2Y option on SS and standard on Firehawk (but never available on WS6). But most people don't care for the single outlet tailpipe on a Trans Am style bumper with the dual provisions for tips.
Last edited by RPM WS6; 01-26-2015 at 03:49 PM. Reason: Corrected sizing information.
Mine was converted by ASC on the 2nd to last day they did '98s and it has the SOTL. So I kinda doubt that any '98 WS6s got the '99+ dual outlet exhaust (this would be the first I've heard of this speculation). GM was not legally compelled to comply w/ the new noise regulations (that prompted the switch to the dual '99+ setup) until the '99 MY. Considering that when GM orders assemblies from suppliers for a production run, they order quite a few "spares" for repairs / replacements, I seriously doubt that the production line ran short on SOTLs and started pulling from the '99 parts bin to finish the run of '98s. Also, there was a strike the delayed the completion and delivery of the last of the '98s, so it was likely that they had more spare SOTLs left over than they had planned for.
You might be correct, it may never have happened. It's just speculation on my part based on something I remember reading well over a decade ago, at a time when these cars were not very old and first hand stories of production oddities were easier to come by. But I have no proof either way myself, and if yours is that late of a production date then it stands to reason that the other story was probably false/mistaken. It's possible that someone may have been confusing fresh '99s as leftover '98s on a dealer lot, leading to the mistaken information.
I think if you polled the 1st owners of any '98 SS or WS6, very few of them found them just sitting on a dealer's lot. In fact, my salesman pointed out that mine was the only WS6 ('98 or '99) available "east of the Mississippi" on the day I purchased mine. He may have been blowing smoke, but my own personal experience looking for one would support his assertion. Without a doubt, initially LS1 f-bods were either in short supply or in high demand, or both. All the more aggravating is that GM blamed "poor sales" for killing off the twins after '02. I don't think I've ever seen more than a handful of LS1 f-bods on dealer's lots up through the end, sitting right next to them were rows and rows of Cavaliers and Grand Ams.
When I bought my own WS6 on July 11, 2000, there were quite a few of them lined up at O'Hare Pontiac (formerly Ridge Pontiac) in Des Plaines, IL. Mine was red, and there was also white, pewter and black available....and that was just WS6s (there were a few base Trans Ams and a Formula in stock that day as well).
On the Chevrolet side of things, I only recall a couple V8 Camaros available in late July of '99 when I bought my '99 Z28 at Jennings Chevrolet also in Glenview, IL, and none were SSs. Several months later that same dealer had a black SS in their showroom, but only a handful of V6s and Z28s otherwise. That black SS was nicely optioned with the SLP dual/dual catback, something I never noticed on any model that was ordered for regular dealer lot inventory, so perhaps someone ordered the car but the deal fell through.
There was a time when the F-bodies sold well into the 6-digit numbers, but by the late 4th gen years I think the combined annual totals were usually around ~75k units for both makes and all models combined. I guess this wasn't enough to justify any redesign or updates to keep the platform in production past 2002.
On a personal note, I wish I could still buy brand new 4th gen F-bodies today - and I would. If the only thing they had changed on the 4th gen was to replace the LS1 for an LS3 in current models, I would be 100% happy.
You are correct I remember the 98's and 99's we had a hard time getting our hands on them at first you could order them all day long but the orders got kicked out and or rejected due to the limited numbers in the supply chain and or parts restraints for specific combinations.
Really I didn't start seeing significant numbers of SS' and WS6' until 2000 model year. Really the 96 and newer SS were kinda rare to see you saw one here and one there but they were few and far between you felt like you had a really special car having a SS or WS6. 2000 Is when to me it seems like they really started cranking out SS and WS6's in pretty big numbers and you started seeing on road a lot more often.
When I was in high school my senior year I ordered a hugger orange 96 SS with a stick and I got all the looks everyone revered the SS badging it was kinda cool like 1969 all over again.
Wow bad timing. I pulled the stock exhaust off of my low miles ARZ LS1 last October. Had it on Ebay for a couple months for $60 but got sick everyone wanted me to ship it to them for nothing. Literally took to the scrap man last Saturday. Sorry dude
