Total noob question, firebird, formula, trans am
What's the difference!? I have done some searches and what I'm really after is the difference in looks. See, my car "looks" like a Trans Am but on the title it says, "Firebird Formula". I realize I have the WS6 hood and I have heard of some people swapping the Formula front bumper for a Trans Am one because it flows air better. But it seems like a lot of trouble adding the Trans Am wing so it leaves me a bit confused. I "think I know what a Formula looks like vs. a Trans Am but I'm not sure.
So this is a Trans Am-
And this is a Firebird-
Correct? And what then does the "Formula" package add?
firebird from 98-02 was a v6
formula is a v8
trans am is a v8
ws6 , aka the ram air hood was option on a formula and trans am . On the they all say firebird formula , if its a formula or ta .
the formula looks like a v6 firebird , but isnt as flashy .
formula is a v8
trans am is a v8
Ok, on the title even if it's a Trans Am it'll still say "Firebird Formula". Strange. And there can be a WS6 Formula AND Trans Am, didn't know that. Are my pictures correct? So I do have a Trans Am then...
LS1Tech Administrator
Received 1,466 Likes
The title always says "Formula" for a V8 Pontiac F-body of this era since the VIN only indicates either a V6 Firebird or a V8 Formula - if it's a Trans Am trim level, then this is indicated via the SPID sticker (RPOs) but not within the VIN itself.
Yes, you have a Trans Am if your car looks like the first picture you posted above. An actual "Formula", as mentioned above, is cosmetically identical to a V6 Firebird (other than badging) but has the V8. This is a lighter weight car than the Trans Am and is for Pontiac buyers who wanted the V8 power but without the excessively flashy looks or standard features of the Trans Am. For example, starting in 1998 t-tops and leather were standard on Trans Am, but both were still optional on a Formula.
WS6 package, like the Firehawk package, could be had on either a Trans Am or Formula. Only catch here is that WS6 Formulas were only available through the 2000 model year, so there are NO original '01/'02 WS6 Formulas. They were very low production (I seem to recall 232 units for 2000, 175 units for 1999, and I can't remember how many for 1998).
Very good info, thanks. After I looked at my title I thought somebody went to a lot of trouble to make my "Formula" look like a T/A hahah. Now I know what the real deal is.
The reason the title does not distinguish between a Formula and a T/A is that they both have the same engine (V8).
The insurance companies want to know what's under the hood so they know how much premium to charge to offset the higher likelihood of having to un-wrap your car from a telephone pole if you have a V8.
The state wants to know how much tax to charge you to pay for highway maintenance for cleaning all the rubber off the roads.
The RPO codes in your glovebox will tell you absolutely everything about the car (at least when it was stock) Formula will have a W66 and Trans Am will also have Y83. It will also tell you your axle ratio, and all the options your car was ordered with.
http://www.compnine.com is a great resource that will give you a build sheet code by code and what each is (just need your VIN)
I have a few more lookups available on my comp nine account if anyone wants one
If this sticker is not present, and compnine doesn't have your VIN information, you can go to any GM dealer and ask the parts department for a VIS printout of the RPOs and build information for a given VIN. It won't be on a sticker, but all the data will be there.
There are absolutely no RPO codes in the glove box of any LS1 F-body. The SPID sticker is found on the door side of the driver's door jamb.
Also FE2 is upgraded suspension? Shows just a 3rd of cars had that option.
Finally the REAR 2.73 only 406. That is a tall gear but seems idea for my driving and given the torque of the LS1 it gets off the line plenty quick.
I just pulled mine for five bucks. Is this supposed to be all the options for this car's VIN. Everything seemed right except that it shows RPO U75 Antenna, POWER(Chrome) PWR ANT. Which mine is a single fixed mast, does this perhaps mean that there is power as in amplification going to the antenna?
I just pulled mine for five bucks. Is this supposed to be all the options for this car's VIN. Everything seemed right except that it shows RPO U75 Antenna, POWER(Chrome) PWR ANT. Which mine is a single fixed mast, does this perhaps mean that there is power as in amplication going to the antenna?
FE2 I believe was the standard suspension on the V8 cars (better than the V6's). Quite a few more V6s were sold than V8s.
For '96-'02, 2.73 (GU2) rear was standard on V8s w/ the A4. 3.23 (GU5) was the only option. All M6 (V8) cars got 3.42 (GU6). V6's w/ A4 came w/ 3.08 (GU4) standard and 3.42 (GU6) optional. All V6s w/ M5 had 3.23 (GU5). Axle choices were more limited prior to '96.
Originally Posted by Jaxem
Huh, did not know this, they're in the glove box on the LT1 F-body's....guess you learn something new every day
firebird/trans ams should be power antennas, only the camaro had the fixed antenna that I'm aware of. are you the original owner? perhaps a previous owner swapped it out after the power antenna went belly up or you have a failed power antenna in the up position like mine was when I bought it.
I just received my Tennessee Title model listed as FAM
personally I don't listen to regular radio anymore, I have my tablet with literally several weeks (14.8 days) worth of uninterrupted music on it to choose from so In my case the antenna was stuck up and antenna motor unplugged (because all did was make the grinding sound) so I just smacked it (from the top) till it collapsed all the way down and have never looked back. FM Radio sucks and is not worth fixing it.
about 28 gigabytes worth mostly in 320kbps MP3 (all the ones I've ripped from CD) but some are lower bitrates because I couldn't get them in higher rates.
it's a lot more convenient then lugging around 120+ CD's, and thats not even going into the music that doesn't exist on CD like the Hard Target (see youtube for songs, he puts most of it there) mixtapes he released for free online.
First you had the Firebird
Then there was the Firebird Formula which had the V8 and the body was identical to the V6.
Then theres the Trans Am. It had different bumper covers, an actual spoiler, leather seats, T-Tops and bigger side skirts.
The WS6 was a Ram Air hood, lifted air box, slightly stiffer suspension, 17'' wheels with 275 tires on all 4 corners, 2.75in catback ( non WS6s had 2.5 I think ) and if the car was an automatic, it only came with the 3.23 rear end. 3.23 was optional on non WS6s.
RPO GU5 (3.23 rear) was in fact a required option for WS6s with RPOs MX0/M30 (auto trans). It wasn't actually standard nor part of the WS6 package, and thus was listed separately on the window sticker - but it was required content for WS6 w/ MX0.
The "stiffer" suspension was just a front sway bar upgrade to the 32mm 1LE bar with stiffer bushings (base V8s received a 30mm bar), everything else was the same as other base model V8s in terms of suspension (or at least that was the case with the '00 WS6 that I bought brand new). I've read reports over the years that earlier LS1 WS6s ('98-'99) *may* have come with 1LE springs, but I don't have any personal confirmation of that. Most of the improved handling of a stock WS6 over the base models came from the 17x9" wheels and 275/40 tires.
The power steering cooler (RPO V12) was also a standard part of the WS6 (and WU8 [SS], and WU6 [Firehawk]) package starting with the first LS1s, though not standard for base V8 trim levels until later years.
