Gas gauge reads "Full Tank" Check Gauge
I have a v6 2000 Pontiac firebird I just purchased this car and the fuel tank reads "Full" but a couple days later the "check gauges" light came on and the "check engine" light. As soon as these lights came on the fuel tank gauge drops to empty. A few days later the "check gauge" and "check engine" light turned off and the "gas gauge" goes back to "Full". Any suggestions?
The F-bodies are known for their sending unit contacts getting varnished over. My '02 Z28 did something similar, with the gauge showing a full tank followed by an empty reading and "check gages" light (Canadian spelling?). Sometimes the fuel gauge needle would bounce back and forth. I let the fuel level drop in the tank and dumped some Seafoam in it. After a while the gauge started functioning properly again.
Ok so I had time to mess around with my bird yesterday, the check engine light is on for my oxygen sensor bank 2. I went to the gas station which was $1.95 a gallon and put $30 on pump 4, and little do you know it stopped at $19 and some change. So the bird now has a full tank for sure but I believe I pumped in around 10 gallons.
But I'd like to know what other people say
