Power antenna
Power antenna
My son has a 2002 Trans Am WS-6. How can he disable the power antenna so it doesn't destroy itself going up when there is ice on the car ? I'm pretty sure when there is ice and snow on the car it's only a matter of time before it doesn't work at all. He wants the antenna to stay up so he can still listen to the radio. I'm hoping there is a fuse he can remove to get this done. Thanks
it definitely doesn't need to be up to get radio, i tried to replace my broken original with one off of ebay, it looked about the same, but i never could get it to go up and down well, so it stays down and works great. If you get into the area with the actual antenna, there's some wires running to the motor that you can cut (and later splice should you choose) to keep it from moving up and down
I put a small switch in my ashtray spliced in between the pink wire, see post #3 for wire location: https://ls1tech.com/forums/stereo-el...ml#post5923441
