Oil Pan Help
Oil Pan Help
I have a 00 Trans Am WS6, block is cracked. Found a new engine without intake, sensors, or oil pan, no big deal I'll swap them over. During disassembly I found that my oil pan is also cracked. While searching I came across a cheap 2002 Corvette ls1 oil pan for sale. Will this fit mine without clearance issues? Has anyone tried it?
Vette Oil Pan bottom
Vette pan top
Vette pan top
Thanks for all the help, the shop ordered an OEM for $290-ish that included the gasket, tube, windage tray/baffle. Just curious, is the oil pump located inside the oil pan too? Since I have the new one I'd rather not have to take the old one off at all. Doing a compression test on new engine block tomorrow then will start transferring all parts to new block. Not taking off the old one will save time. Plus I'm sure there's going to be an awful lot of metal down in there.
-Randall
-Randall
