How do i remove guage cluster on my 2000 Firehawk?
its very easy.
1. remove the knee panel, then angle the steering wheel in its lowest position
2. remove the tilt lever by unscrewing.
3. Remove the little cover behind the turn signal stalk by pulling it toward the front of the car.
4. remove bolts/clips on bottom of gauge bezel if you have not already when removing knee panel.
5. Pull gauge bezel back by unsnapping the clips and move it out of the way.
6. remove the 4 7mm bolts holding the gauges in then remove electrical connector once removed.
7. reinstall reverse
