'71 Firebird stalls after warm up?
So I recently bought this Firebird and I'm not much of a carb guy honestly so I thought I'd ask here. The car starts right up and runs great until it doesn't. I have only driven it once so far. I got it home and fixed a coolant leak then drove it for about five minutes down the street and back and it ran fine. Then I drove it over to my sister's house which is about 3 miles away, another five minutes. I parked it and waited for her and her husband to get ready and we went to go eat. About ten minutes into the drive it started running rough and stumbling then would stall while driving. The longer I drove it the worse it got. We stopped to eat for about an hour and I took the car to get gas not knowing if the fuel gauge was faulty or if it had bad gas in it. I tried to make it home (about fifteen minutes/under ten miles) but it loaded up really bad and even back fired. A few minutes later it stalled again and we towed it home. It starts and idles fine, until it gets hot it seems.
It started back up to get it into the driveway. It also started back up to load onto the trailer then into the storage unit where I'm keeping it. It seems to not like getting hot?
The car seems to be mechanically all original. If I remember correctly it has 106k miles on it. It has a 350 with the tiny Rockchester 2 barrel. Just before I got it some basic maintenance was done to get it up and running. I'm not sure how long it sat before then.
I just want to get it running reliably, I'll make it fast later (455 or 462). My race car is my primary money pit right now this is just to cruise.
Any idea? And who doesn't like pictures...
do you smell fuel when it starts to act up? I few things come to mind.
with it setting for a while, your needle in the carb could be gummy, not sealing off the fuel supply once the float bowl reaches proper height, or the float could be off, or sticky.
i'd run come carb cleaner through it. if all else fails, get a rebuild kit for the carb. a 2bbl carb is easy to rebuild.
another thought, is that an electric choke? or hot air choke? once the engine is hot, can you verify that the choke is fully opened?
Backfire was through the exhaust. It starts fine when cold so far.
No I haven't. It's kept in a storage facility about 30 minutes from my house and I haven't messed with it since I put it in there the day after it started messing up. The only thing I did was fix a coolant leak then tried to drive it.
Ya that's what my friend said. He thinks maybe distributor or maybe the choke is sticking.
Haven't gotten that far yet but will look into all of those as well. I might switch the intake and carb or I may be fine with the way it is depending on how it feels. I'll be doing either a 455 or 462 eventually but for now just want to cruise it. I'll post up what I have soon. Not so many pictures since I just got it and now it's in storage. Thanks for the compliment!
In order- fix this current issue, replace the exhaust , drive it as often as I can and enjoy it. Then depending on funds either just replace the carb with a four barrel (and intake) or just build the 455/462.
