Trans Am / Firebird Taillight Filler Panel Overlay
Old 08-13-2018, 11:48 PM
Freddgs's Avatar
Default Trans Am / Firebird Taillight Filler Panel Overlay
Does anyone know how to properly install the decal. And does anyone know how to take off the original off the filler panel
Old 08-14-2018, 07:03 AM
bleepster's Avatar
we took our original one off by wet sanding and then polishing. use 1500 grit to remove and then followed by 2000 grit. then polished using a headlight restoration kit
as for the new overlay - steady hands, good eyes and wing it. spray area with soapy water, put on decal and slide it around until you get it where you want it, then squeegee out the water. let it set and peel off the backing
Old 08-14-2018, 03:12 PM
Freddgs's Avatar
Did you just sand down the decal or the whole filler panel
Old 08-15-2018, 06:57 AM
bleepster's Avatar
just the decal area is all we did. it doesn't take much.
