Did some 02 Trans Am's come with LS6 intake??
I remember reading that somewhere, is it true?? I also heard some came with in LS6 block too?? If it is true, how can you tell?? Does it really make that much difference?? thanks
i'm sure that this has been discussed on here somewhere, i couldn't find it though.....if it is drop me the link
ALL 01 + LS1's came with an LS6 intake, all the way through the 04' GTO's. You have about a 15% chance of having an LS6 block on an 01' and a 25% on an 02', the power gains (from the LS6 block)? None, its all in the heads and LS6 cam, although the LS6 block is suppose to get more oil to places.
Originally Posted by 02SLPTransAm
right on well......how do you know if you have an ls6 block??
I Think Trust Is Pointing You In The Right Way. And It Is All In The Heads And Cam . All Ls1 In 01,02,03 Came With Ls6 Intake. As To The Block The Camaro May Have Had A Couple Out There , But On The T/a I Don't Think They Came Out With The Ls6 Block.
The 01+ engines have the 6.0L cam which doesn't require the EGR. So to make it cheaper GM installed LS6 intakes on all LS1 engines.
Here's the scoop on finding out if you have an LS6 block. (aside from the impossible to read part # on the back)
Right below the throttle body on the block you will see a "bullseye".
If it looks like 2 or 3 rings and looks like a bullseye, you have the LS1 block.
If that same area is filled in and you see an outline of a circle, but no circles inside the circle.. you have an LS6 block. Plus the LS6 aluminum is not as shiny as the LS1 version.
I have an LS1 block... oh well. ~Joshua
Originally Posted by OctaneZ28
According to information from the horse's mouth, all 01s & 02s have LS6 blocks.
Originally Posted by cascadesys
Sweet, so I guess I have an LS6 block. I feel special.
What sort of benefits if any does having an LS6 block over an LS1 block?
Slightly more reinforcement in the webbing, and the alloy is slightly stronger than the LS1 alloy.
Performance gain compaired to a 600hp motor using an LS1 block...ZERO.
ok all ls1 01 and 02 have the ls6 intake correct. and some have the possibilty of having a ls6 block. i have also heard that there is a difference in the head and cam on the 01 and 02. is this true and what are the differences
Copy & Paste Moderator
Here is the FAQ from the "New LS1 Owners & Enthusiasts" section:
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/213148-jrp-s-faq-commonly-asked-questions.html
Here are the posts from there about the differences between years:
https://ls1tech.com/forums/showpost....80&postcount=2
https://ls1tech.com/forums/showpost....81&postcount=3
https://ls1tech.com/forums/showpost....83&postcount=5
Here is the post from there about how to tell if you have a LS6 block:
Here are the cam specs over the years:
https://ls1tech.com/forums/showpost....87&postcount=9
https://ls1tech.com/forums/showpost....84&postcount=6
All of this and plenty more is available in that FAQ (thanks to JRP).
