do steering wheel controls on LS1 cars light up?
i've noticed in my BUK the controls get really hot.
gotta love that GM quality.
a very helpful member PM'd me with this:
http://www.stevendbrown.com/Steering...oControls.html
first is gonna be the fuse check for me.... the controls fuse is good, but it was suggested that the control lights have their own fuse. i'll check on that tonite.
Wonder if my lights use LEDs too like in the link above (my design is different). Props to GM for doing that instead of like the door handle light. You'll pretty much never have to worry about them going out. They may get dimmer, but they'll last years. Also, if you're good at soldering you could change their color simply by buying other ones.
They're called Surface Mount though, here's a site if you're ever interested.
http://www.ledtronics.com/ds/smd-0603/
my door handle illumination was already replaced before i bought the car.
sweet!
Thank you all for the info.
The controls on my new car don’t light up.
I couldn’t remember from my last car if they did or not.
Ill get to fixing it tonight
thanks again!
thanks again!
also.. use a proper desoldering iron to remove the old bulbs.
Im just wondering if the dash cluster, and heat controls use simmular bulbs, because I found blue, and green 12v 50mA bi lead lamps... I dont like the stock orange. Im sure that the radio is leds, but I can work around that.
this fix works perfect.
I vote sticky
I checked out the dash, and most of the controles.
It looks like a color change is possible but very difficult, so Im going to live with the red.
I vote sticky
