Every Tech should have this LS Timing cover Alignment Tool!
AlignIt Tools are used to align the Rear Main and Timing Covers and install the seals!
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9- LQ4-LQ9- 5.3-6.0 and all GM v8's from 1997-2013 Timing and Rear Main cover and seals. Works with all LS based engines!
Here is a couple simple but very effective tools to help you make easy work of aligning your Timing and Rear Main Covers. CNC Machined to exact tolerances, the AlignIt tools
get the covers centered perfectly with the crank. The O-ring design makes for a perfect snug fit no matter the temperature that can cause expansion/contraction of engine covers, crank & tools
that will hinder a perfect fit. The O ring design eliminates this problem. After the covers are centered and torqued down, use the AlignIt Tools to install the seals in seconds!
Available in the Pro Series 6061 Aluminum Anodized and the standard PVC Plastic. Both are CNC Machined to exact specs from Billet materials.
www.saccitycorvette.com/AlignItTools.html
If you're doing a Rear Main Seal or Engine Build, its a good time to start keeping unfiltered oil out of your bearings and lifters! Check these Billet Oil System Improvement parts out!
https://www.saccitycorvette.com/OilS...provement.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Christian
__________________
AlignIt tools work on LQ9's, LQ4's and others!
__________________
The AlignIt Tool makes it a lot easier with less chance of leaks. But it has been done other ways.
Thanks
Christian
__________________
Thank you XTINCTION, for you business!
Christian
__________________
AlignIts work on L99's also.
__________________
Thank you everyone that purchased products from SacCityCorvette! Your business is greatly appreciated!
__________________
A must have tool for that cam or oil pump change to prevent oil leaks. Definitely worth the money. I damaged a seal installing without this. Looks like the new ones have slots for the keys. I don't recall mine having that.
P.S. Seeing that the last posts were before Christmas, Tell your wife it would make a perfect stocking stuffer. Nothing better than getting tools for Christmas unless of course its high performance car parts.
Thank you DoUSail2 for the kind words!
When the AlingIt tools first came out they did not have the slot for the the keyway.
Thank you,
Christian
Thank you,
Christian
__________________
All of our products are in stock and ready for same day shipping.
__________________
Thanks Sparky!
__________________
Hi,
If you have your engine torn down, doing a rear main seal or have your pan off you might be interest in these oil system improvement items.
You can find how they work to improve your system here.
http://www.saccitycorvette.com/Billet-BarBell.html
Thanks
Christian
Thanks
Christian
__________________
Hi all!
If you're doing an engine build or cam swap, these tools will help prevent premature seal wear and leaks.
https://www.saccitycorvette.com/AlignItTools.html
Also, while doing that build or rear main seal, its a good time to install our Billet Barbell to help keep unfiltered oil out of your bearings and lifters.
Check out our Billet Oil System Improvement Parts.
Thank you,
Christian
Thank you,
Christian
__________________
All Tools and Parts in stock when you're ready! Same Day Shipping!
Thank you,
Christian
Thank you,
Christian
__________________
We hope everyone is doing well and staying safe during this crazy time of the virus.
Just wanted to let you know, while we are practicing the virus safety precautions, we still have our same day shipping of our products.
Stay safe and let’s get through this!
Christian
SacCityCorvette
Christian
SacCityCorvette
__________________
