Time to go low 11's
Time to go low 11's
I have all mods in sig... I just ordered a full ported 92mm and ported TB along with 42lb balanced injectors. I also got sick of the nitto's the 60's made me want to finally and ordered a set of MT's and drag bags to fit them under the wheel well. Over the winter I plan on purchasing a IRS 8.8 with axels subs gears driveshaft. I am hoping this will help deliver the retuned 470+wrhp that I should get out of this setup.
I am guesing though, budy making 30 less horse than I am pulled a 11.8, with the 92 full port and ported TB ill be a good 50 more rwhp on his set up. With gears and a stout rear end I am sure it will get deep into the 11's. Should be making 470+ at the rear and with the rear end set up I should be able to cut low 1.7 to high 1.6 in the 60. Without the rear I believe it will still go mid to high 11's
yeah the rear gears well easily get a 3-5 tenths off with good traction(dead hook)
