Getting Dynoed and tuned on Monday
Hey guys i want to know what your opinions are on my HP and TQ when i get dynoed next Monday. Where do you think i will be? Im hoping for 350 to the wheels.
The set up so far is K&N CAI, BBK 80mm TB, Pacestter LTs, Stock cats, X pipe.
Im getting it tuned also while its there.
Thanks for your feed back.
M6 will dyno higher than A4. What brand dyno? Dynojet will give you a higher number than a Mustang. With a M6 you should be close, maybe 330-340 HP. If you have an auto, you're gonna be really disappointed.
17,16,15,14,13,12,11 Drvr
with the same mods except I have an u/d pulley I put down 344/357 Good luck
I forgot to add I tuned it for 12.5 afr, if they tune it for a 13.0 it will be higher.
I have high flow cats on it already. I did it when i did the headers. I also did an X pipe but i think im going to go to an H pipe because the X is a little raspy.
Yeah, an underdrive pulley will free up another 8-10 HP. If you ever plan on doing a cam change, that's the perfect time to do the UD pulley. Not a lot of bolt-ons left other than a FAST 92 intake manifold and bigger TB (but that's expensive). A full catback might be good for another 5 HP, but that's not a good bang for the buck.
get yourself a ported fast intake its like 1100 bux but you will see 20-30 rwhp out of it
you should be around 330-340 i dont see you makeing much more than that with a ls1 even with a great tune
If i was going to spend 1100 bucks i would just do the cam swap. Also i dont see the FAST manifold giving me an extra 20-30 rwhp over an LS6 manifold. Maybe like 10 rwhp. I would really like to get a cam but i cant convince my wife to let me get it. I have to find a good priced one on here or something.
and his wasnt even ported
but you are correct over a ls6 intake you will only see about 10 to 15 if you are lucky...i thought you were running stock
Yeah thats what i was saying. I already have the LS6 intake so it didnt make sense to me to spend a grand on a FAST intake only to gain another 10 HP. I was saying if i wanted to spend a grand i would spend it on a cam swap and gain roughly 30 HP.
The ported FAST 90 ended up gaining about 27 HP on my 2004 LS1. But, I admit, it's not a big bang for the buck like a cam swap would be. I thought you wanted to know about other bolt-ons, that's why I mentioned it.
So, dyno results???
So, dyno results???
