Pontiac GTO 2004-2006 The Modern Goat
drag wheels for a gto
Old 01-27-2010, 10:10 PM
sandovalt1's Avatar
Those are just plain sexy. I think we just found the wheels for your car nick lmao
Old 01-28-2010, 06:27 PM
CoolAid's Avatar
Sick. Looking forward to the new Weld offerings. I cant do the 4x4 looking massive sidewall of the 15s in the front. No offense. Dont want to carve up my PBR calipers to get them to fit either. Cant do a 17'' front and 15'' rear either. My OCD wont let me ruin my cars smooth flowing and perfect look.
Old 01-28-2010, 09:29 PM
BillyBob750's Avatar
Weld Pro Stars
15x3.5 1.75BS 26x7.50 Mickey Thompson Sportman Fronts
15x10 7.50BS 26x10.0 Mickey Thompson ET Drags
Up front, you can just bolt these one and rock out. In the rear, you'll have a little bit of work but nothing major. First off, you will need drag bags. You have to bend your brake lines at the caliper slightly.. We used a ratchet strap to put constant pressure on the lines, and bend them slowly in the direction we needed. This will keep you front kinking or breaking a line. You will also need to grind the welds on the lower control arm slightly. There is plenty of matieral there, so I took quite a bit down just for peace of mind. The dust cover on the shock will rub slightly on turns and whatnot. Mine dont see but a quarter mile of action at a time, so I didnt mess with this any. You can remove the dust cover, or spaces the shocks inward if you wish. You will also need to install ARP extended wheel studs. Should take about an hour from start to finish to do all of that stuff.
Old 01-29-2010, 08:02 PM
badpontiacs's Avatar
The new weld r/t series will fit over the calipers from what I am told.
Old 02-01-2010, 04:51 PM
nmcqueen469's Avatar
New welds are SICK!!!
Old 02-01-2010, 09:11 PM
batboy's Avatar
I know most of you want to run 15" drag wheels, but these SSR wheels are lightweight and work well for 17 inchers.
Old 05-09-2012, 12:56 AM
tonka's Avatar
Nice very nice will have to decide between the staggard 17 or 18 inch set up asap.
Old 05-09-2012, 08:54 AM
joeyagls1's Avatar
Originally Posted by badpontiacs
You can run bigger than that with little mods. I run 15x10 with a 275/50r15 slick and I didnt have to flare anything.
With those 275 size, they do not rub at all? I want wider tires,just scared of rubbing. Looking for weld pros with m/t
Old 05-09-2012, 08:55 AM
joeyagls1's Avatar
I am going to buy a set up with m/t with weld pros. I know jegs has these tires/wheels.
Old 05-09-2012, 09:29 AM
402GOAT's Avatar
thread from the dead lol
Old 05-09-2012, 09:31 AM
402GOAT's Avatar
mine are Race Stars. 15x3.5 and 15x10
Old 05-09-2012, 04:59 PM
  #32
Monza355's Avatar
What tires do you run?
Old 05-09-2012, 06:19 PM
  #33
gconnoyer's Avatar
Old 05-09-2012, 08:50 PM
  #34
BSGTOLS2's Avatar
Here is mine
Attached Thumbnails drag wheels for a gto-022.jpg   drag wheels for a gto-003.jpg
Old 05-09-2012, 09:39 PM
  #35
402GOAT's Avatar
i think they are hoosiers
26x4.5x15 front runners
275x50x15 rear dot drag radials
Old 05-20-2012, 11:17 AM
  #36
brokenfly's Avatar
weld magnums in action...
http://www.youtube.com/watch?v=c2kO4...&feature=g-upl
Old 05-20-2012, 11:27 AM
  #37
brokenfly's Avatar
here's a better shot of the wheels...
i plan either to anodize entire rear wheels gold or polish the outside diameter of those fronts to sorta match the rear wheels some more...
http://www.youtube.com/watch?v=fcvE3...feature=relmfu
Old 05-26-2012, 01:33 PM
  #38
hardcore's Avatar
I finaly got a chance to test fit my new Weld RTS wheel and QTP Tires
Wheels are 15x8 with a 6.5 BS Tires are Hossiers QTP 27x11.5x15
They should tuck nicely
I had to clearance the inter fender wheel and grind the Lower contral arm about a 1/16
255 vs. 295
255-60-15 you can see how pulled under the car they are
295-50-15 0 air in bags Total tucking a 12" tire
Old 08-15-2012, 02:36 PM
  #39
lighning#1's Avatar
did you have to roll the fenders or anything to get the back ones to work? i'am still learning i just bought my gto from a friend an the car is slammed on pedders lowering springs i dont know what would fit on the car. It's got oem 18's an bfgoodrich g forces on it now 235's an its right at the fender lip almost touching.
Brandon
Old 08-15-2012, 02:49 PM
  #40
hotrodth's Avatar
hardcore your car looks SLOW....
Quick Reply: drag wheels for a gto
