Unknown connector....
Ive got a 06 M6. Ok guys so I've been trying to figure out why I have no reverse lights and I was going to look into the fuses but my hazards work and the rear blinkers are linked to the reverse lights so it can't be that.
I popped off the carpet in the trunk and noticed this white connector on the passenger side and nothing connected to it. Anyone know what this is for?
Not really sure what that connector is if it's on the passenge side. As far as the reverse lights go, it's a common issue with the reverse switch going bad. I believe Its mounted on the trans on your car.
I have that same connector that is unplugged. when I pulled out the tank to put in a new fuel pump, I saw that connector. and since mine is unplugged also,I would look into the reverse switch going bad.
