05 gto paint help
05 gto paint help
i recently bought a new gto. its black and i was wanting to paint the gto plastic part underneath the bumper. ive never done paintwork before and was wanting to try it out. any help on what the process should be would be greatly appreciated.
Because of its location id just use some formula 2001 on it to shine it...if you put any paint down there as soon as you touch a curb it will start peeling and look worse than it does now
It's been so long since I had that peice I can't remember if its textured or not....if its smooth is sand it with 400 grit wet paper, if its textured I'd use fine scotch brite.
Then spray on some adhesion promoter
Then use a paint like (rattle can) Fusor from Krylon that is made just for plastic...spray it as thin as you can because the thicker the paint is the easier it will chip and flake
i sprayed mine two years go, took it off, masked it, cleaned it and used some krylon plastic paint then clear coat. steal looks good, starting to show red since the rocks hitting it but im doing it again lol
