new setup
new setup
I never have posted pics on here of my current car or my last one but I'm getting excited about this GTO(been apart for 9 months)
at pinks all out
I just dropped in a new engine
12.2:1 383c.i. Small bore LSx
4.8/5.3 truck block machined by Jerry's Motor and Machine in El Reno, OK
Wiseco 3.903 forged nitrous pistons -2cc valvie reliefs
Wiseco ring pack with steel top and napier second. Gapped LARGE x HUGE for nitrous
Callies 6.125 rods
Callies 4" crank
Clevite main, rod, and cam bearings
Texas Speed ported oil pump
Rollmaster double-roller adjustable timing set
LS7 hydraulic roller lifters
Custom COMP Cams cam ground for nitrous
Factory roller rockers with COMP trunion upgrade
COMP magnum 7.425 pushrods
PRC 227cc cylinder heads with 61cc chamber and PRC .675 lift springs
COMETIC .040 head gaskets
ARP main studs
ARP head studs
ARP 2000 rod bolts
thinking it may run pretty good
custom wheels ok not custom just powder coated factory 17's rears wrapped with Hoosier drag radials 275/40 17
at pinks all out
Callies 6.125 rods
Callies 4" crank
ARP main studs
ARP head studs
ARP 2000 rod bolts
You'll be luck if you don't blow the welfare on your intake and loose that peice of diamond plate you have bolted on the passenger floor the first time you run it lol
No, but seriously man you have got a sick sweet set up there!
thanks guys
she's an A4 built to handle 1000rwhp followed by DSS one piece aluminum drive shaft, BMR axles all built to handle 1000 rwhp also I have the 5/16 raised rear drag springs from Pedders.
best n/a 60' last night was 1.835 I need to learn to tune this thing myself so I can tweek it at the track.
thanks guys
What converter are you running? I've lost a few very well built a4's because of the converter clutch going out, then taking out the front pump....then you know what happens lol.
Yup, found out first hand when my 3400 ptc spit shavings into my 60e. I now have a Vigilante 4000 stall in it. The converter already feels night and day better than the ptc i had before. Can't wait to get to the track with it.
second I ran a 4 eyed stang on the bottle to my motor spun for about 75' then drug his ***
third run was a motor pass also against a supercharged nitrous fed silverado with my wife driving my car. I should of turned the bottle on for her.
Thanks for the compliment man the old car is fun to drive when it's not shitting parts
I wish I had a gopro!!!
the guy that was videoing everything is all butt hurt because I sold someone parts that he said "I want but I'll get with you sometime" and another guy said "I want the entire package today!! will you take cash??"
needles to say I took the cash that day. and I won't get video from him anymore
I know several people that have done the th400 swap in their f-bodies, and if I ever go auto ageing that is the way I would do it....but after 4 tranny swaps in mine (dead 4l60s) I swapped to a good old 3 speed Saginaw manual
