PSI for drag strip
PSI for drag strip
I will be going to the strip next month on my new set up, right now I am running nittos nt05's drag radials, what is a good psi I should set them at for good grip?
Haven't used those myself, however with Mickey Thompson it took a bit of trial and error.
LS1 running 245/40/18 M/T's need to be dropped down to 15psi to get traction.
265/40/18's with same engine worked all the way up to 26psi.
Changed to LS3 and the ideal number is 21.5psi.
These are all with high stalled auto.
Yeah the conditions are for sure I have to check for, hot cold sunny? you know, thanks man. I will be testing and tuning and then when I am about to race I should have the right PSI.
I done everything except the machining on the heads tb an intake.
Yeah everybod is saying around that area so will do man, thanks.
