Overheating issue So my 04 GTO is starting to overheat. Not much but it's creeping up. Normally I run around 179 coolant temp but I'm seeing it climb to 190-ish but mostly sitting at a light. The fans are coming on, the coolant is full and I replaced the cap on the overflow tank. Any ideas what could be causing this? Thanks! |
check obvious things first. leaks,condition of coolant and maybe your Tstat. |
No leaks and I'm not losing any coolant. I didn't think it would be the thermostat because the temp fluctuates. It tends to go up sitting at a light or in traffic but cools down a bit when moving. Not sure how to check the condition of coolant but I'll research. Thanks! |
when youre sitting does it keep going up be because if your tstat is operating properly it should keep your coolant circulating to maintain a safe temp. i had a 160 in my GTO and it would never get hot. on really cold days my heat barely worked lol. |
190 isn't abnormal sitting at a light |
Originally Posted by GTO1_OHIO
(Post 19147384)
190 isn't abnormal sitting at a light and i like that 10.9 too. nice work. i still miss my GTO. it was a great car. they still are. |
Originally Posted by ULTIMATEORANGESS
(Post 19147332)
(Post 19147384)
190 isn't abnormal sitting at a light I guess I can keep an eye on it but I hate ignoring something that could be a bigger issue down the road. |
I've seen it as high as 220* on idle. These motors run pretty warm. If you're that worried about it I'd do a complete coolant flush or at least burp the system. |
I'll burp it this week but still change it since I don't know the last time it was done. The dex-cool still looks orange and there isn't a lot of miles on it (29.3k) but it's better to be safe than sorry. Thanks all. |
First off, the temperature gauge is a dummy gauge that only reads cold, midrange and hot and it moves the needle to those "ish" ranges after it is triggered at a certain temp. There is a hidden menu in the DIC that you can access: Hold the two menu keys MODE/SET and turn the ignition key on without starting the engine, your instrument cluster should show that you can arrow up/down to different parameters that you want to see. Select coolant temp and then start the motor and watch the live readout. It will default back to normal when you turn the key off so you will have to do the mode/set BS each time you want to see any of the hidden menu items. |
2004 GTO fan temp kick in I have a 2004 GTO and i was wondering: how do you adjust at what temperature the fans turn on and off? Is it something I can do at home easily or something I have to go somewhere to get done? |
you would need tuning software (hptuners, efilive) or a handheld tuner, such as a diablosport. |
© 2024 MH Sub I, LLC dba Internet Brands
