1 pc DSS driveshaft.
I had an early aluminum one piece and had that looseness. After commenting on it Frank at DSS got a hold of me and said he'd send me a new adapter years after it was out of warranty. That made me a customer. The new plate came with longer bolts with lock washers and nuts. The original just had the bolt thread into the yoke. I never had a problem again . I've now stepped up to a DSS carbon fiber as my HP exceeded my aluminum's rating.
I built myself a custom cf shaft years ago when I use to make kits and it has extra noise attenuation built in.
At the end of the day, cf is the way to go in the platform imo.
The only noise that I get is an occasional "ding" when shifting from reverse to drive. That's the slack in the half shaft joints. I did have to adjust the trans angle. I had a little vibration so I measured the angles, raised the trans and shimmed, no more vibrations. Not a DSS shaft but it's aluminum.
