Pontiac GTO 2004-2006 The Modern Goat
Fuel pump relay
Old 10-29-2017, 02:14 PM
Speedfreec88's Avatar
Default Fuel pump relay
hello, first post !!just registered,have a quick question about the fuel pump relay on a 06 GTO I just want to bypass it to drain my fuel tank.. looked everywhere, Google search, YouTube, found one video but the guy did not specify which two slots to put the wire into. Any help on this subject would be greatly appreciated, thank you
Old 10-29-2017, 08:35 PM
dreadpirateroberts's Avatar
the diagram on the side of the relay should tell you that.
Old 10-30-2017, 11:06 AM
Thanks!! I saw that but wasn't sure which 2 would run the pump
.. for future reference tho, 3&5 without the key on worked.
Old 10-30-2017, 10:56 PM
the terminals that are linked to the switch are for supplying power to the device
the terminals that are linked to the solenoid are the trigger or signal
Old 10-31-2017, 11:18 AM
Exactly! I'm learning, not knowledgeable enough on the electronic side of cars..
thanks!!
Old 11-22-2017, 02:43 AM
moviehall24's Avatar
Default good post
thnaks for posting this post.
Quick Reply: Fuel pump relay
