Removing a single-peice driveshaft?
Putting a new tailshaft seal in, I can't quite figure out how to get my Hinson shaft out. I have the trans off the cross member and the differential down off the subframe, but it still doesn't have enough space to come out!
To pull it? Depending on the motor mounts it maybe part of why you can't get the tail shaft side to go in further.
When I installed mine I had a hard time lining up the keyway. Might be under tension, that could keep it from going in further? Is there room for it to go in further
