climate controls No high Fan Speed!
Check the resistance at the output of the resistor assembly as follows (I think it's the resister {4}):
Blower Motor Resistor Assembly
Low Speed Resistance
2.8 ohms
Medium 1 Speed Resistance
1.5 ohms
Medium 2 Speed Resistance
0.6 ohms
High Speed Resistance
0 ohms
2.8 ohms
1.5 ohms
0.6 ohms
0 ohms
you probably blew the fuse in the engine compartment fuse block. check that.
i think it's the rear window defroster fuse, from the diagram. same thing happened to me once, and it took me a minute to figure it out.
