Rear cradle alignment tool
Hey guys new here. Had my 2004 gto for about 2 months and am currently dealing with what i think is a pretty badly misaligned rear cradle. My drivers side rear is rubbing the inside of the wheel well the score marks are evident. It eventually destroyed my drag radial. The passenger rear tire is rubbing the fender lip which does not bother me as i am getting them rolled anyhow. I just got my pedders rear cradle bushings and the bolt kit from wretched should be here this week. I was wondering if anyone in the area has a rear alignment tool i could rent or borrow to get the job done. If not i will be attempting to get it straight without it as i haven't frond anyone who is capable of doing the job, any advice would really be appreciated. I am located about 1/2 hour north of philly. I really just want to get the car on the road and running straight
Just replaced the springs with pedders zero drops and had bags before that. Shocks are still stock i plan on doing big bores when the time comes. It has to be the cradle alignment unless the subframe is bent or some other structural damage. Springs were defiently sagging as the tires were wearing on the inside.
Mine did it when I swapped to 18's. I.also have the subframe bushings I've been setting on. Mine only happens on harsh bumps and some right turns. I've considered digging into the rear sway bar and it's bushings Before I go through with subframes, there was a write-up on ls1gto I read through but don't remember the alignment being.mentioned
It's not the rub that bothers me it's the wheels being uneven to the point where the one rubs pretty much constantly on the wheel well on the inside of the tire not the fender. Fender rub can be solved by rolling and raising the rear but you can't fix a tire being to close to the wheel well aside from Bfh mod or mini tubs. The cradle alignment in theory should spade the wheels evenly in the wells.
