2004 GTO power at starter relay none at so;enoid - LS1TECH - Camaro and Firebird Forum Discussion
Go Back  LS1TECH - Camaro and Firebird Forum Discussion > VEHICLE SPECIFIC FORUMS > Pontiac GTO 2004-2006
Reload this Page >
Notices
Pontiac GTO 2004-2006 The Modern Goat
Old 07-08-2018, 02:14 PM
Default 2004 GTO power at starter relay none at so;enoid
2004 GTO 200,000 miles intermitant problem has become perminant car will not crank with key battery full charged starter relay is grounding as it should but when 30 and 87 are connected still no power going to starter solenoid. If I jump across power to terminal on solenoid car will crank up and run. Are there any more safety switches between starter relay and solenoid. The wire from 87 terminal does not go straight to solenoid
speedtriple is offline
Old 07-09-2018, 11:08 AM
Jontall's Avatar
Document ID# 1488479
2004 Pontiac GTO
5.7L LS1 Engine - No Start - kw battery cable charging column connector crank electrical entry fuse generator ground housing ignition inopeative intermittent power short switch #PI01944 - (Apr 1, 2004)
When servicing the vehicle with the VIN you entered, the following diagnosis might be helpful if the vehicle exhibits the described symptoms.
Condition/Concern:
A no start situation with the 2004 Pontiac GTO. This concern appears to be a dead battery but is traced to a circuit open in the steering column. A purple wire in the ignition switch has been found to be backing out, resulting in a no start. When the wire pushes out of the connector, the vehicle displays the same symptoms of a Flat Battery.
Recommendation/Instructions:
To fix the problem, you need to:
•Remove the steering column upper and lower cover.
•Remove the (black) connector backing cover.
•Pry open the wire retaining tang.
•Push the wire back into the connector until it snaps into place securely.
•Fit the connector back into the cover and reassemble all previous components.
All GTOs built after 3/10/04 and VIN L250294 have been checked and certified to be without this concern.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance. This diagnostic approach was developed for the vehicle with the VIN you entered and should not be automatically be used for other vehicles with similar symptoms.
Models:
(2004 Pontiac GTO)
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Copyright General Motors Corporation. All Rights Reserved.
2004 Pontiac GTO
Jontall is offline
Old 07-09-2018, 03:17 PM
Jontall's Avatar
Jontall is offline
Old 07-14-2018, 07:09 AM
Thank you very much this will be a great help
Quick Reply: 2004 GTO power at starter relay none at so;enoid
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
