BMR SubConnector users
For those that have installed and welded their BMR SFC's, how was the process? Was there any issues you ran into? Anything I should look forward to, or expect?
Did a few searches, and I only found one person that had issues mounting the bar. Other than that, I'm still wanting to know if there is other info out there on personal experiences.
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
LOL! Hey, as long as that was the only problem you endured during the entire process of them, I'll take that as a wildly successful install, minus the **** welds. But, luckily it's underneath, so I wont feel TOO bad to show anyone the car. HAHA! Thanks for the reply.
Installed shortly after purchased the car in 2004. No issues then. Bolted on rear, welded the front. Well a shop did. Someone who was experienced with welding. Still wheel hopped although car is still quite tight in DD use at 54,XXX miles. I did install some polyurethane sub-frame bushings at the same time.
Installed shortly after purchased the car in 2004. No issues then. Bolted on rear, welded the front. Well a shop did. Someone who was experienced with welding. Still well hopped although car is still quite tight in DD use at 54,XXX miles. I did install some polyurethane sub-frame bushings at the same time.
The main benefit I think has been to avoid speed bump induced rattles and squeaks. I am glad I did it.
Good luck. GTO a nice car to DD. Be ready for little things to crop up. Bound to happen with any car after so many years.
Thanks, Man. I'm doing a overhaul on everything. It's been fun, but needs a bit more work.
I'm the odd man out with owning a GTO, and I'm not drag racing it. So, I'm about to be getting rid of my radius set up, because I'm going with a custom built front control arm set for drifting. The guy that makes them is pretty well known in Australia, and there is another dude in the Bay Area that has them on his drift goat (he's pretty out there with followers and sponsors).
