Notices
Pontiac GTO 2004-2006 The Modern Goat
2005 gto tuner reccomemdation
Old 12-11-2018, 12:32 AM
Default 2005 gto tuner reccomemdation
Hello everybody, new to the gto world and this forum as i picked up my first one 3 weeks ago and love it!! However i did make the mistake of cleaning my throttle body by removing it completely and now have the infamous high idle and code p0507 problem. Ive searched every inch of forums for the last week straight and have tried every single thing ive read in order to fix it however nothing is working. Im worried to drive the car as ive read that with the computer reading so much air intake while idling it could possibly retard timing and therefore cause my headers to glow and possibly a lean condition leading to blown motor. The only thing i havent done is buy a brand new tb (bought used one didnt fix problem) or take it to a tuner. That leads to my question. Can anybody on here with experience please lead me to the best tuner here in las vegas for our cars? The car has long tube headers with high flow cats and a pipes x-pipe muffler, cai and ported tb. Thank you in advance for any suggestions on the best tuner. Looking to fix my problem the cheapest route then possibly get it dyno tuned afterwards.
72chevy is offline
Old 12-11-2018, 11:38 AM
dw456post's Avatar
Nick D is in Vegas. He is a member on here.
If you sprayed your tb, you probably got cleaner on the circuit board. But, Remove the negative battery cable for 15 minutes and then put it back and see if that will reset anything. Anytime you are going to remove an electrical component, remove the negative terminal first.
dw456post is offline
Old 12-12-2018, 02:03 AM
Thank you for the reccomemdation. So the computer mustve learned idle position on its own since the last time i drove it to work and back (30 miles) as it idles perfectly now. Was throwing lean codes on both banks but i narrowed that down to the brand new maf sensor i put in tryinf to fix the idle issue. Swapped back to my original maf and bam no more lean codes. As for the tuner ive scheduled a dyno tune at revolution raceworks here in vegas. Hope frank there does a bang up job for me! Thanks again
72chevy is offline
Old 12-12-2018, 07:04 AM
dw456post's Avatar
The computer doesn't learn anything on its own. Your O2's adjust short term fuel trims. Your tuner will fix it up.
Have fun with it.
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
