transmission lines?
transmission lines?
Looking to add an additional transmission cooler, the correct routing of lines would be, bottom line from trans to bottom of radiator, top line from radiator to additional cooler, from cooler to top line of transmission. Correct? Thanks for any help.
Kevin
Kevin
I originally had the cooler going thru the radiator with the extra cooler, heard it was suppose to be better to just run it by itself, did that but it was cooler when going thru the radiator, so I want to change it back the way it was but can't remember the routing of the lines.
Kevin
Kevin
Kevin
Kevin
