04 M6 GTO Build list/Advice
JEGS performance parts
- LS1,Ls2,Ls6 Intake manifold 555-513050
- 102 mm TB 555-14526
- SLP LM exhaust
- catless mids
- pacesetter long tube headers (Armor coated)
- BTR stage 3 cam
- 799 heads
- supporting mods- lifters, valve springs, oil pump, fuel pump, fuel injectors, gasket kit, timing chain, fuel pressure regulator, push rods,
Are you talking about before the intake manifold? Like what people usually get and actually think its effective without a tune? Lmao. I've thought about it, but honestly I think the stock intake will be alright. I know a lot of people that keep it stock until they throw on a pro-charger and they are forced to change.
Just saving money over fast, either way the flow is higher and close enough to the fast intake that its worth it for half the price. Just needed something with heads to wake up the cam
Btw, that intake isnt going to "wake up the cam".
The following 2 users liked this post by Kfxguy:
kurazy kracka (04-16-2020), Pulse Red (04-16-2020)
There is a YouTube channel named Josh's car corner that recently installed the MSD and had some fitment issues with it. Worth looking at the video and channel. Cool guy. I guess very few GTO owners had put those particular intakes on. However it is designed for the ls2 fuel rail so if your a ls1 car you'll have to swap that also.
I've heard of a ported ls6 intake, would that be a better alternative? Im really looking for a larger throttle body because with the mechanical TB's you get a quicker response, so throwing in a 92 or 102mm will make it more responsive.
On the manifold, just go with the FAST and be done with it. I fooled around with stock, stock ported, etc. None compared to the FAST once I finally put one on. No fitment problems. I even port matched it myself. Should have done it a LOT sooner.
Also, the stock clutch can't even hand stock power, do yourself a favor and put in a better clutch now during your build to save having to change it after you get the build done.
The following users liked this post:
GTOenthusiast (04-19-2020)
