04 GTO Alternator Wiring Help
Hi everyone! I’ll get straight to the point!
I have an LS Swapped 350z and I has a 04 GTO 2 Pin Alternator… It used to charge but all of a sudden, it stopped. Naturally I figured its the alternator because I saw my voltage gauge drop to just 12.0-12.5 while driving.
Took out the alternator and had a shop rebuild it. It was tested good but when I slapped it back on, car is still not charging.
I ended up redoing my whole wiring system for my alternator and it goes as follows:
4G wire from Battery + to Alternator Post
GTO Pin A connects to Battery +
GTO Pin B (Exciter Wire) connects to an Ign Switch source with the 470ohms resistor in line.
I do not know what else it could be? Maybe I’m doing something wrong and someone else can help me diagnose.
