Current Sales at TBYRNE Motorsports
Stainless Works Headers/Exhaust Special -
We have a special that covers all headers and exhausts that Stainless Works products. You will receive a $20.00 rebate and free t-shirt from SW. Plus we are offering 10% off, free shipping in the 48 states and a free TBYRNE Motorsports t-shirt with your purchase through 10/31.
STS Turbos And Accessories On Sale -
We are offering $250.00 off all of the STS Turbo kits and 10% off the accessories that you order at the same time. On August 5th, STS received a CARB EO #, for the Camaro, 5.3L/6.0L GM Trucks/SUVs and the Pontiac GTO. These turbo systems are covered under EO# D-593 so CA residents can now bolt these on and enjoy!
Sale pricing will be running through Octorber 31st.
BMR Suspension Products On Sale -
We are offering 10% off all BMR suspension products that are ordered through Sunday evening (10/23). This discount can be taken off of the regular prices that you see on our website.
Predator Programmers $399.99 + FREE Overnight Shipping -
We have the Predator handheld programmers for sale at the lowest level that DiabloSport will allow us to sell them for! They are $399.99 and we are including FREE overnight shipping to you in that price (48 states only). The Predator programmer has many features that the others do not! Besides upgrading your vehicle's PCM for better performance it also allows the user to make some adjustments and can read / erase fault codes, monitor live data as a diagnostic tool. Details for specific vehicles can be seen on our website.
This offer also applies to the 2005 LS2 Predators. We are expecting them to be released very soon and are currently taking pre-orders to provide you with one of the first that become avaialble.
SLP "ZL402" LS1 and LS2 short block assemblies on sale -
We have a sale that covers all of the SLP ZL402 short blocks. High and low compression versions are available for the LS1 and LS2 assemblies -
The ZL402 LS1 based iron stroker short block is loaded with the kind of top-quality hardware found in short blocks costing much more. It was the first choice for the experts at Car Craft magazine, who took an off-the-shelf ZL402 stroker motor and produced over 575 horsepower, naturally aspirated.
Our ZL402 is built around a new GM LQ9 Gen III 6.0 liter block, a 4.00" forged steel crank, and 4.00" forged aluminum pistons.
This package is sold only in short-block form, minus manifolds, camshaft, oil pump, and other equipment. The advantage of this approach is it allows you to pick a combination best for you.
Although designed primarily for use in late-model F-Bodies and Corvettes, the ZL402 also makes a great choice for street rods, muscle cars, and trucks. Best of all, it's sold outright, eliminating the shipping hassles and expenses of core returns.
You won't find a higher-quality, better value LS1 stroker motor anywhere!
LS1 High Compression Features -
Built entirely from brand-new parts.
Sold outright, no cores required!
GM LQ9 iron 6.0 liter block (includes block plugs)
4.000" Eagle 4340 forged steel crankshaft, balanced to rotating assembly
4.000" Ross 2618 forged alloy pistons with -6.00cc dish (includes new rings and full-float pins)
402-CID displacement
Eagle 6.125" H-beam rods
Includes new, factory-installed cam bearings; Clevite rod and main bearings
11.3:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
Designed for naturally aspirated applications
Capable of supporting up to 600hp
Meticulously assembled to OEM tolerances and specifications.
Oil pump, timing chain, camshaft, pans, plates, and covers not included.
ZL402 OEM-quality fender badges (pair).
LS1 Low Compression Features -
4.000" Ross 2618 forged alloy pistons with -28.50cc dish (includes new rings and full-float pins)
9:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
Capable of supporting up to 700hp
NOTE: SLP STRONGLY recommends that final assembly and installation be performed by an experienced, professional mechanic. Assembly/installation instructions are neither included nor available with this part.
The regular price for each of the LS1 short block assemblies is $3549.99. We are able to offer each of them for only $3299.99 through October 31st!
12400 Crate-Engine Assembly, ZL402" LS1 Short Block (High Compression)
12401 Crate-Engine Assembly, "ZL402" LS1 Short Block (Low Compression)
The ZL402 LS2-based aluminum short block builds on the success of SLP's original ZL402 iron short block. This new package uses the same race- proven internals as its iron block predecessor but features the all- new LS2 block for weight savings of over 100 pounds compared to an LQ4/LQ9-based engine.
Although designed primarily for use in late-model F-Bodies and Corvettes, the aluminum ZL402 also makes a great choice for most late-model GTOs, street rods, muscle cars, and trucks. Best of all, it's sold outright, without core charges.
LS2 High Compression Features -
402 CID displacement
GM LS2 aluminum 6.0-liter block (includes block plugs)
11:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
6.125" Eagle H-beam rods
Includes new, factory-installed cam, rod and main bearings.
Comes with everything required to retrofit into an LS1-equipped car or truck
Designed for naturally aspirated use.
Assembled to OEM tolerances and specifications.
Capable of supporting over 600 hp.
Oil pump, camshaft, pans, and plates not included.
ZL402 badges (pair).
LS2 Low Compression Features -
Capable of supporting over 700 hp.
The regular price for each of the LS2 short block assemblies is $3949.99. We are able to offer each of them for only $3699.99 through October 31st!
12412 Crate-Engine Assembly, "ZL402" LS2 Aluminum Short Block (High Compression)
12413 Crate-Engine Assembly, "ZL402" LS2 Aluminum Short Block (Low Compression)
*These items must be prepaid with a certified check or money order. Please contact us to receive a shipping quote to your location.
We are also offering DEEP discounts for all ATI and Vortech Superchargers. Just give us a call to receive a quote!
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763)
How about a sale on a full long block LS 7 crate motor with computer, harnesses, and aux. at about $7,000.00? Now that would be a sale. Just dreaming, sorry Tom.
DT
DT
