c5 wagon wheels
i was wondering if a c5 wagon wheel would fit a 04-05 gto. reason why i ask is a friend from el paso tx wants my rims but we dont know if they will fit??!!!
thx frank
thx frank
While they may "fit" they, nor any other GM RWD wheels, will have the correct bolt circle. GTO is 5x120.0mm bolt circle, while most all GM RWD are 5x4.75" (translates to 5x120.65mm). The difference is small, but IMO you're still better off sticking with the correct bolt circle. Also the GTO wheel hubs are 69.5mm, which is smaller than standard Corvette wheels (which I believe are 70.5mm), so if nothing else a hubcentric adapter ring would probably be required.
